ignition wiring
ignition wiring
All my wire labels feel off. I guess masking tape is not intended to last two years. What wires connect to the positive side of the coil? I am guessing the one wire from the distributor and hot switched wire from the car. Now the is a condenser looking thing (ignition noise suppresser?) attached to the coil bracket. Does that connect to the negative terminal?
every book I read has " Connect in same order as removed" Not much good if you can't remember what wire went where.
Joe Mc
Joe Mc
Re: ignition wiring (70vetteinpieces)
The red/pink from goes to the positive side of the coil. The black to the distributor. The radio capacitor on the positive side.
