Manual trans bracket, what funtions does it serve?
That black bracket at the rear end:
See one on the t-5 I bought and am not sure what it does and if I need to try to hook it up. My muncie does not have one like that.
Re: Manual trans bracket, what funtions does it serve? (Fevre)
your Muncie's bracket is attached to the frame......not sure what the purpose the Tremec bracket....since that is a top loader
Re: Manual trans bracket, what funtions does it serve? (GDaina)
My TKO didn't come with any brackets like that :confused:
Hummm, don't remember anything but a tranny mount last time I pulled it so I will have to check it out when I pull the muncie tonight. Maybe bubba forgot/left it off before me. :confused:
I believe that some models use a torque arm from the rear end to that bracket. You would not use it in a C3.
That's what I'm talking about, the bracket that the shifter is mounted to.
Also double as the exhaust hanger brackets.
Did some prelim measurements and if I can get the exhuast to fit I should be able to mount it like it is in the f-body and use the hyd clutch and the stock t-5 shifter may even line up right through the existing hole in the trans tunnel.
[Modified by Fevre, 7:42 PM 1/24/2003]
