Stupid question RE: Brakes
This is really stupid, and shows how much of a retard I am when it comes to brakes...
Both chambers on master cylender should be full of brake fluid, right? My brake pedal pressure is massive, I really have to haul on the brakes to get it to stop, finally I looked at the resivoir, and the back chamber is almost empty. Is that right?
Stupidly, :conehead
David
Stupidly, :conehead
David
Re: Stupid question RE: Brakes (djlangford)
Yes Both should be full. If you have a real hard pedal it sounds like you are having a problem with the booster. First check that you are pulling vacuum, then make sure you valve plugged into the booster is operating correctly.
Hope this helps.
Bob
Hope this helps.
Bob
