Photos of VanSteel offset trailing arms (before and after)
Old 01-23-2003, 07:22 PM
phoenix
Support Corvetteforum!
phoenix's Avatar
Default Photos of VanSteel offset trailing arms (before and after)
I am finally getting around to installing these. :)
I figured that I'd post a few photos before I did.
A couple of photos of the old bent and rusted arms and then a few of the new ones. :D:D:D
I'll post some more photos as I get everything together. :)
(Where is that big sh** eating grin smilie? :D:D)
[Modified by phoenix, 7:25 PM 1/23/2003]
Old 01-23-2003, 07:30 PM
PatsLs1vette
PatsLs1vette's Avatar
Default Re: Photos of VanSteel offset trailing arms (phoenix)
There gone to look sweet on there :thumbs:
Old 01-23-2003, 07:32 PM
Stoge
Stoge's Avatar
Looks expen$ive.
Old 01-23-2003, 07:39 PM
mapman
mapman's Avatar
phoenix,
My Van Steel rebuilt trailing arms are not offset but they look just as nice. :cheers:
The old ones I sent them looked like your BEFORE pictures. Its like Christmas when the big brown truck arrives!
Old 01-23-2003, 07:48 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
They look just like mine :D :D :D
:cheers:
Olivier
Old 01-23-2003, 07:55 PM
Rogue Wave
Rogue Wave's Avatar
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Those pics bring back memories of last September.
Good luck :cheers:
Old 01-23-2003, 10:14 PM
78Vette-SA
78Vette-SA's Avatar
Default Re: Photos of VanSteel offset trailing arms (gb4622)
I love before and after pics. :smash:
Old 01-23-2003, 10:18 PM
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
Sweet!!! What size meats are you going to go with?
Old 01-23-2003, 11:08 PM
81vette
81vette's Avatar
Nice pics. Thanks for posting.
:cheers:
mark
Old 01-24-2003, 03:18 AM
JoeC427
JoeC427's Avatar
:cool: :cheers:
Old 01-24-2003, 06:25 AM
'79ProwlerOrange
'79ProwlerOrange's Avatar
Default Re: Photos of VanSteel offset trailing arms (smokin75-427)
id like to do these when i get arround to the suspension. let us know how they work for you. :cheers:
Old 01-24-2003, 06:33 AM
groovyjay
groovyjay's Avatar
Looks :cool: hope they'll :steering: well
Old 01-24-2003, 08:43 AM
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Very cool, they look nice. I've been considering switching to offset t-arms to gain more tire clearance in the back. keep the pictures comming.
Old 01-24-2003, 08:53 AM
phoenix
phoenix's Avatar
Default Re: Photos of VanSteel offset trailing arms (burners)
Thanks guys.
Realistically, anything will be better than my old t arms and bearings. The driver's side T-arm was actually bent about 15 degrees. This made it impossible to align and the left wheel was about an inch forward of the right.
Now for a question. I bolted on the left t-arm last night (PITA because of the weight and sharp edges), but the leaf spring bolt hole doesn't align with the bolt when in the T-arm. I tried jacking the spring up until it was almost flat (the entire weight of the car was on the spring) and it still seems like the spring either needs to move forward about a centimeter, or more likely the spring needs to be taken apart and realigned. It is a newer steel 9 leaf with most of it's life left, but there may be a slight angle to the position of each leaf on the spring. Could this be my problem?
Anyone have any recommendations?
Should I loosely bolt the spring to the diff and then get the spring attached to the trailing arms and then tighten the spring to diff bolts? Would that allow it to shift? (It's against the ridge on the diff cover so there isn't much room)
Any comments appreciated.
Thanks. :)
Old 01-24-2003, 09:05 AM
tshort
tshort's Avatar
CI 7-8 Veteran
Phoenix - How much $ did those set you back?
Old 01-24-2003, 09:29 AM
phoenix
phoenix's Avatar
Default Re: Photos of VanSteel offset trailing arms (tshort)
I needed both new trailing arms, one spindle and bearing. They were able to rebuild one spindle and bearing, my rotors were turned and aligned with the spindle/bearing, I also had newer SS parking brake hardware that they planed and reused.
The total cost with shipping was $1131 to a local CF member's shop. He gets a discount from them.
I am very happy with the appearance of them. The T-arms are built much better than the tubular stock ones.
Old 01-24-2003, 09:38 AM
74-Roadster
74-Roadster's Avatar
St. Jude Donor '06
Father & Son St. Jude Donor '09
Thanks. :)
Has the spring been there a while? You said your left wheel was 1" forward of it's proper position. Just wondering if the spring was in place when whatever happened to bend your TA also did something to your spring to keep it from lining up?
Also, please be careful compressing your spring with just a jack . . . Scary what would happen if that let go when you were working down there.
To Photos of VanSteel offset trailing arms (before and after)
Old 01-24-2003, 09:56 AM
BB68Vett
BB68Vett's Avatar
When installed a new rear spring in my car, I also had the problem of the holes at the ends of the springs not lining up with the holes in the trailing arms. I loosened the bolt holding the spring leaves together, aligned the bolt holes, installed the bolts and then retightened the spring bolt holding the leaves. I don't remember if I took the spring back down once it was realigned or whether that little bolt tightened up with the spring installed. Either way, that's how I did it. Hopefully, it works for you.
Old 01-24-2003, 09:58 AM
phoenix
phoenix's Avatar
Default Re: Photos of VanSteel offset trailing arms (BB68Vett)
Thanks... I'll give that a try.
I have a couple of "C" clamps that I use to prevent any problems, but I agree... could be very scary if it slipped.
Old 01-24-2003, 10:39 AM
fauxrs
fauxrs's Avatar
Looks very familiar - I was doing the same thing this time last year - I had no alignment issues with the spring hole so I cant help you there. - it will mean day an night for handling and stability though - you will love them.
[Modified by fauxrs, 7:40 AM 1/24/2003]
Quick Reply: Photos of VanSteel offset trailing arms (before and after)
