15x10 rally rims anybody have them on there vette?
I tried fitting my brothers 15x10 rally rims on tonight and they hit the e -cable bracket so i removed it and they fit fine with 275/50/15 drag radials.I was wondering if anybody has them all the way around even in the fronts,i really like the deeper look they have and i can get a whole set from a guy i know.And if anybody has pictures of them installed too.
Re: 15x10 rally rims anybody have them on there vette? (Gordonm)
theyare 5 inch backspacing and Gordon, im not sure if theyll fit an 8 inch rim there about a 12 inch tire there actually bubbled on the sidewalls on a 10 inch rim,ill take a picture so you can see and also i think with my 275/60/15 tires on the 15x10's theyll be even with the fender but with the drag radials they stick out.
Re: 15x10 rally rims anybody have them on there vette? (patsnitrovette)
excuse the dog :D i couldnt put the cap on either cause i didnt have the right lugnuts no acorn ones to put on.Im gone to move it to the front tommorrow and see how they fit up front.
I thought the 8 inch would be small. 10 inch would be better.
Thats a big tire. Like the purple side pipes. :jester
[Modified by Gordonm, 7:46 PM 1/23/2003]
So you are gaining an inch on the outside and an inch on the inside. From the looks of the picture, you would almost have to go with a fender flare to avoid cracking a fender on a speed bump. They really look good though :cool: ...even with your fancy purple side pipes :jester
Re: 15x10 rally rims anybody have them on there vette? (Ed T)
:D Thanks Ed,34 tommorrow,im catching up to you. :jester almost everything im supposed to beoff tommorrow for my bday but there calling me in to work :mad
[Modified by patsnitrovette, 9:15 PM 1/23/2003]
I have 8" ralleys on the front with 255-60-15s and it barely rubs the inner fender at full lock. I would think 10" ones with such a wide tire would rub or worse yet hit the fender (crack!!) since mine completely fill the front fenderwell. They look mean on the back tho! I was wondering if you'll have to change the speedo gear since they look shorter height than stock. BTW, my sig pic has the old F70-15s, not the BFGs I'm talking about here.
Man, you got everything....purple side pipes! Who could ask for more!!!
Just kidding! :blueangel:
Those tires will look killer! :thumbs:
Re: 15x10 rally rims anybody have them on there vette? (JohnS_77)
im only gone to use the rims on the rear not the tires my brother wont give up those,ill use my 275/60/15 on the rear,fills the wheel well up better.
Hmm ... they look pretty sweet.
Who makes a 10" rally wheel ? Did they come on other GMs, or aftermarket ?
Also - was there a good thread on your sidepipe fabrication ? I'm definitely
going there - purple or not !! No use hiding them - they are right in the sig text. :crazy: :crazy:
I have the 275/50/15s in 8" rims 275mm=10.83 inches. Fit great even with E-Brake bracket in place. also have a set of 275/60/15s on Alum 8" rims, might sell these , new BFG drag radials with 200 miles.
PatsNitrovette : I think the combo of the 275/50 with those 3.70 gears is perfect. I am not sure you will like the 275/60 as much . I have the 3.36s and the 275/60s killed my gearing. not so much in your case, I guess...
chris :flag
[Modified by Clink69, 2:28 PM 1/24/2003]
chris :flag
Re: 15x10 rally rims anybody have them on there vette? (Clink69)
clink,i had the 275/60's for awhile with the 3.70 gears and yeah it hurt the take off but now with the 700r4 first gear in it ,its feels great...also wheel vintiques sells them.
