Factory Distributor specs for '71 base eng
I need to know what the factory specs for my distributor are. Stop bushing degrees,total degrees availble in dist. trying to recurve it but would like to know what it was set at from the factory. Thanks
Re: Factory Distributor specs for '71 base eng (BEZ71)
It's not everything you want but this page has some specs. Should be enough to establish the OEM advance curve. Top right side. http://www.71corvette.com/sun1.jpg
Larry
Larry
