LOUD pops
LOUD pops
IM just trying to knock off my problems 1 by 1 so here is the other 1
my alighment has been off some time now and everytime i turn the wheel, forward or reverse i hear a loud pop. This only happens at slow speeds like it so loud you can hear it many yards away. Its almost like a soundsing like something pops back into place then i try to turn the wheel. its at the same points basically.
Anyhelp...
thanks again
-dave
Anyhelp...
thanks again
-dave
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: LOUD pops (Chris O')
sounds like it.
Take the thing to Midas for one of their free inspections. Let them find all the problems your car has and give you an estimate.
Don't be surprised if you need 4 new ball joints, control arm bushings, tie rod ends and a idler arm.
Most older C3's need to have all these replaced and it will go a very looooong way into making your car much more drivable.
Re: LOUD pops
yea my car is comming up on time that it needs to get everything done but im running out of money fast
breaks
tires
shocks
alignment
all that suspension stuff most likely
thanks i will take it down... ill do anything to get that imbarasing sound gone 4 good
breaks
tires
shocks
alignment
CI 6-7-8 Veteran
Re: LOUD pops (HcDave1)
I rebuilt my entire front end last year. I got the kit from Zips (you get a 5% discount if you order through the Corvette Forum). They have 1 entire kit with new bushings, ball joints, idler arm and tie rod ends. It was about $200 for the kit with poly-bushings.
If your handy with the tools you can do the work in a weekend or take the parts to the local shop. It will be a lot cheaper than what they can get the parts for. Labor for that can be between $450-$700.
Re: LOUD pops (BSeery)
well 200 bucks sounds good to me, i know i could knock it off in a day or so......
how do i order throught the corvette f.? and what is the exact kit you recommed thanks still need to come up on some money but thats in the range i was looking to spend and it doesnt hurt to save 5%
thanks
thanks
