Pics of my old fuse panel...
Old 01-21-2003, 09:13 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Pics of my old fuse panel...
Well - here are pics of my old fuse panel.. The contacts were so corroded that they wouldn't make good contact anymore...
:cheers:
Olivier
Old 01-21-2003, 09:34 PM
78Vette-SA
78Vette-SA's Avatar
Default Re: Pics of my old fuse panel... (GrandSportC3)
Eeeeck! :cry
That blows (no pun). Looks like well worth the effort to change!
Old 01-21-2003, 09:35 PM
GrandSportC3
Default Re: Pics of my old fuse panel... (78Vette-SA)
Eeeeck! :cry
The contacts were so bad that some of the electric equipment didn't work properly.. With the new "Painless" fuse panel - everything is working perfect now!!!
:cheers: :cheers: :cheers:
Olivier
Old 01-21-2003, 09:40 PM
74FLCONV
74FLCONV's Avatar
That's what happens when you live near the beach! Although I'd suffer with a little rust to live on Miami Beach any day... (.)(.)
D. Ocean
Miami, FLA
Old 01-21-2003, 09:54 PM
GrandSportC3
Default Re: Pics of my old fuse panel... (74FLCONV)
D. Ocean
Miami, FLA
Well - the condo garage is below ground level and completely closed off.. The fuse panel was already rusty when I got the car.. Luckily - the rest of the metal parts of the car is pretty much rust free... The main problem is that the original owner of the car relocated the fuse panel to the engine compartment without covering it... When I got the car - I put the panel in a box to protect it.. However - the damage to the contacts was already done...
:cheers:
Olivier
Old 01-21-2003, 10:07 PM
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Good grief, that thing is fried! I can't believe it worked at all. That was a bad choice to place it in the engine compartment. What are people thinking? I hope your new installation is weather tight. I bet the improvement was very noticeable.
backtrail69
backtrail69's Avatar
St. Jude Contributor
that pretty shot
Old 01-21-2003, 10:22 PM
GrandSportC3
Default Re: Pics of my old fuse panel... (burners)
So far - my installation is not "weather tight".. I'm going to build a plastic box that will contain the new fuse panel and protect it. The car fired before - because the starter and ignition are directly wired to the energy and didn't go through the fuse panel... Even the headlights are directly wired...
:cheers:
Olivier
Old 01-21-2003, 10:24 PM
GrandSportC3
Default Re: Pics of my old fuse panel... (backtrail69)
that pretty shot
Absolutely - I always had to remove the fuses and sand down a little bit of the corrosion to get contact again.. That's why I decided to get a modern style fuse panel... I actually thought before on re-wiring the whole car.. but that's just too much work...
:cheers:
Olivier
Old 01-21-2003, 10:44 PM
Budman68
Budman68's Avatar
Cruise-In VII Veteran
St. Jude Donor '07
And the car still runs 12's. Any chance I can install it in mine. It's got be good for a 1/10th.
Old 01-21-2003, 10:46 PM
GrandSportC3
Default Re: Pics of my old fuse panel... (Budman78)
The ignition was directly wired to the ignition switch and therefore not influenced by the bad fuse panel..
:cheers:
Olivier
Old 01-22-2003, 12:22 AM
shoptek
shoptek's Avatar
That could have been a fire waiting to happen. All that corrosion must have really jacked up the resistance on the circuits that were still flowing current. Resistance = heat = fire potential. :eek:
Old 01-22-2003, 02:24 AM
'79ProwlerOrange
'79ProwlerOrange's Avatar
Default Re: Pics of my old fuse panel... (shoptek)
:iagree: Pics of the new panel? :D
Old 01-22-2003, 07:37 AM
GrandSportC3
Absolutely... Sometimes - the Voltmeter only showed 10 Volt instead of 14 Volt :eek: :eek: :eek: . Thanks god that I finally replaced the fuse panel...
:cheers:
Olivier
Old 01-22-2003, 07:39 AM
GrandSportC3
Default Re: Pics of my old fuse panel... ('79ProwlerOrange)
I will make some as soon as I finished installing the cover for the fuse box.. Right now - it doesn't look too great...
:cheers:
Olivier
Old 01-22-2003, 10:16 AM
groovyjay
groovyjay's Avatar
Mine was just like that, no woder nothing worked! Now I have my new fuse box mounted in the stirage compartment behind the passenger seat. It's lot more easier to work on now! :cheers:
Old 01-22-2003, 10:20 AM
GrandSportC3
Default Re: Pics of my old fuse panel... (groovyjay)
That would be a nice location for the fuse panel.. However - too much work to relocated it there...
:cheers:
Olivier
To Pics of my old fuse panel...
Old 01-22-2003, 12:39 PM
adamdinat
adamdinat's Avatar
What was GM thinking when they located it where they did? Could it be any further up under the dash? Moving it was a good idea, just poorly executed.
Old 01-22-2003, 03:09 PM
groovyjay
groovyjay's Avatar
:cheers:
Olivier
Gotta give you that, BUT I think it's well worth it. Your fuse box stays nice, clean and dry for the rest of your cars life cycle! :cheers:
Old 01-22-2003, 03:28 PM
GrandSportC3
:cheers:
Olivier
That's for sure.. I will try to build a weatherproof box for the panel...
:cheers:
Olivier
Quick Reply: Pics of my old fuse panel...
