Bouncing Speedo
Bouncing Speedo
Does anyone else have a problem with there speedomiter needle bounceing up and down when at lower speeds? What would be the cause of something like that?
Thanks
Thanks
Re: Bouncing Speedo (77Dream)
Mine did on my '69 when I got it. I lubed the cable, still bounced, replaced the whole thing, still bounced, replaced the speedo gear and seals, and voila, it works right now.
Jon
Jon
Re: Bouncing Speedo (Jon69L46)
Our '84 Honda did that for awhile but it finally got completely stuck and the cable twisted until it broke. Lubing the cable is probably the first step or just replacing it if it's cheap. My vette did this to but it magically went away for some reason? Maybe it's a summer thing. Hope I helped.
-Chris
-Chris
Well thats not so bad. I was afraid someone was going to tell me it means my engine will blow up if I slow down to below 50mph :lol: :lol: :lol:
Location: If you can read this, thank a teacher. If it is in English, thank a veteran.
Cruise-In IV Veteran
Cruise-In V Veteran
I had the same problem on my '77 L-48. If you are equipped with cruise control, you may have a faulty transducer. You can replace it for about a c-note. :cheers:
Re: Bouncing Speedo (L48Shark)
Cruise-In V Veteran
Re: Bouncing Speedo (Simon Alexander)
Try lubing or replacing your cable first. If no fix, replace your transducer. For the record, my '79 does it too.
