For you Electrical Guru's
Every time I use my turn indicator the horn goes off! I know that it is because the indicator stalk is coming into contact with the column surround, but for the life of me I cannot see how my indicator stalk is completing the circuit since it is embedded in the nylon indicator switch assy. :confused: :confused:
Any thoughts?
Any thoughts?
Re: For you Electrical Guru's (Graemeinvette)
It is providing a ground to complete the circuit. You may have a weak spring on the horn ring, I know that the ring and tabs get bad. Try a search in the archives or FAQ sections and check the diagrams to verify yours is all there and assembled right.
Re: For you Electrical Guru's (72GACRZR)
Henry,
Thanks for that. Is the horn ring you are talking about the brown lamiate disc with the electrical connection?
Graeme :cheers:
Graeme :cheers:
yes, I was trying to find a thread in the corvetefaq site , but it appears to be down. Try to access it and look in the suspension and steering section, as there are some good diagrams there. I am at the offic and don't have any of my books to refresh my brain. maybe Jim Shea will chime in, he is the gru of steering.
I can't resist this one i have to ask when you use the blow the horn does the turn signal go off,just kidding good luck :chevy
[Modified by zone69, 6:53 PM 1/21/2003]
http://www.corvettefaq.com/steering.asp
There I finally got to the faq site. go there and look at the tilt-tele steering wheel articles and you should be able to resolve the problem.
:seeya
:seeya
Thanks Henry there is enough reading here to at least give me an idea of where to look. I did look at the faq site but it didnt occur to my pea sized brain to look under steering for a horn problem :crazy:
