85 has no power--HELP
OK, here's the deal. When I press the go pedal i have absolutely no power, idels smooth, doesn't miss, just no power, like i barely am giving it gas but it is floored. I was thinking fuel pump(new fuel filter already), maybe timing although recently had intake gaskets changed by ASE mechanic for emmissions in dallas, or maybe clogged cat, how would i check for a clogged cat? HEI ignition, something there, coil?? help out of ideas. :cry :cry thanks. Oh another thing, rev up and squirts good gas thr throttle body, but doesn't seem to rev really quick of freely like my 93 cadallac for comparasion
[Modified by LT1driver, 9:57 PM 1/20/2003]
St. Jude Donor '09
Re: 85 has no power--HELP (VETDRMS)
EDIT...DOH !!! my bad....I was thinking you said 84 not 85...
So dont go to the where I said to go...yours is not a crossfire...
[Modified by Desertdawg, 11:07 PM 1/20/2003]
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: 85 has no power--HELP (LT1driver)
What year is this? You say 85, but then mention a throttle body (only in 1982 and 1984) and you posted in C3 (1968-1982).
Re: 85 has no power--HELP (BSeery)
OK, my fault for not being clear, car is cadillac, not vette, no cad sites so thought you guys could help, not concerned about TBA as much as trying to figure if it might be fuel pump or clogged cat. My 70 is smog free machine and only polutes as it should with lots of duration and lieft. :D anyway, any thought on cad problem, sorry again for being unclear
start at the beginning; check the throttle cable. If you press on the pedal and the throttle isn't being moved that could be a problem. Then check air and fuel intake. If all of that is good check compression in all cylinders. After all of that I'd look to exhaust and the CAT.
