Drove the '68 to work today !
WoW ~ can you believe it's 70-degrees in North Texas in the middle of January ??? :crazy:
Drove 'ole blue to work today & home for lunch & back to work again ! :D :cool: :cheers: ......still doing little test runs with the new radiator setup. Gotta get ready 4 those spring cruises. :thumbs:
Anyone now how to treat the 'dieseling' symptom ~ ya know where the car is turned off but still tries to run ??? .....looks like carb. tune-up needed. ;)
Cruise-In V Veteran
Cruise-In VI Veteran
Re: Drove the '68 to work today ! (verskel)
Lucky man. :cheers:
Check your idle adjustment and lower it a bit if it's too high. Hopefully, that's all it is.
Re: Drove the '68 to work today ! (BlueL36)
You guys could almost be twins 2 68's and 2 c5's in the same color...wish it was 70 here ,33 but the wind is kicking today.20 with the wind chill.
John
