I need suggestions to overcome this issue Drv shaft Ujoint/ Yoke missmatch
I purchased a 69 drive shaft for my auto to manual conversion. The Ujoint on the drv shaft Ujoint is wider than the the Yoke. Any suggestions?
Thanks Bob
Thanks Bob
Received 1,877 Likes
2017 C2 of Year Finalist
Re: I need suggestions to overcome this issue Drv shaft Ujoint/ Yoke missmatch (76 Red)
I don't know all the numbers off hand, but go to anny driveshaft shop and they will fix you up easily. They make "two size" u-joints with different measurement on each cross. Some even came from factory that way.
Of course, best is to get larger yoke for trans..probably a 1350 series one it looks like.
JIM
JIM
Re: I need suggestions to overcome this issue Drv shaft Ujoint/ Yoke missmatch (427Hotrod)
In the past I had to use one of these U-joints with different dimentions on each side. It was when swapped a chevy 12 bolt rear into a 71 olds. In addition, I currently use one of these joints in my 84 K5 Blazer. That truck comes with a 10 bolt rear fron the factory. I also swapped in a 12 bolt rear into that which required the use of the same offset joint. I recently had to replace that joint. Went to Auto Zone and found that thier reference material could not find a part for me. Then went to Pep Boys and they fixed me up with what I needed.
Neapco Inc. PN: 3-3130 This might be the exact joint that you could use.
Mine kinda looked like that (maybe not as much) and it just turned out that the cups (spicer) were not seated all the way. I used a C clamp to squeeze them together, and after removing the clamp it went right in. You might want to measure the yokes themselves to see if they're the same inside width, just to be sure.
Re: I need suggestions to overcome this issue Drv shaft Ujoint/ Yoke missmatch (Chris81)
That did not work. It is 1/2 to wide. I am going to look into different sized ends.
Thanks everyone
Bob
Thanks everyone
Bob
