Tremec 3550 and TKO owners.....
Old 01-20-2003, 10:50 AM
fauxrs
fauxrs's Avatar
Default Tremec 3550 and TKO owners.....
I've got a question. I have been communicating with another forum member via e-mail regarding the TR-3550. He asked me if the Tranny I purchased came with an adapter plate similar to the one that is indicated on Forte's Website.
He was wondering if this adapter was required - I assume it is not as my tranny did not ship with any kind of adapter - however much of the installed photos on the site above seem to show some form of adapter.
So the question to the collective members who have already installed one is - "Is there an adapter between the trans and the bellhousing" or not?
Old 01-20-2003, 11:39 AM
zwede
zwede's Avatar
Default Re: Tremec 3550 and TKO owners..... (fauxrs)
On the "GM version" of the 3550 and TKO that forte, hanlon and others sell, no adapter plate is used. The mounting holes on the tranny are re-drilled to fit a GM bellhousing. They also replace the input shaft with a GM 26 spline shaft.
Old 01-20-2003, 12:20 PM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Tremec 3550 and TKO owners..... (zwede)
:iagree: Markus is right on with this one. I think the tremec 6spd may have an adaptor, by my TKO bolted right to the bellhousing. :cheers:
Old 01-20-2003, 03:39 PM
fauxrs
fauxrs's Avatar
Default Re: Tremec 3550 and TKO owners..... (SmokedTires)
Thats what I figured - thanks
Old 01-20-2003, 04:55 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
:iagree: :iagree: :iagree:
Old 01-20-2003, 05:21 PM
zwede
zwede's Avatar
Default Re: Tremec 3550 and TKO owners..... (GrandSportC3)
BTW, check hanlon motorsports. They had the lowest prices last I checked.
Old 01-20-2003, 09:17 PM
71roadster
71roadster's Avatar
Try Swarr Auto. Less than Hanlons, cheaper shipping, and faster service!
:yesnod:
Old 01-20-2003, 09:51 PM
1971Ultra
1971Ultra's Avatar
SmokedTires,
I am interested in this Tremec TKO. A couple of questions
Did you have to mount the shifter in the middle of the tranny?
Did you have to modify your console to accommodate the 5-speed shifter?
What shifter did you choose?
Old 01-20-2003, 10:17 PM
GrandSportC3
Default Re: Tremec 3550 and TKO owners..... (1971Ultra)
SmokedTires,
The shifter mounts in the middle of the tranny.. It's a internal rail shifter.. My mechanic welded a bracket on the shifter to space the shifter to the correct location.. I used a shifter + handle that I bought from a Mustang site...Any Mustang shifter handle + **** will fit...
:cheers:
Olivier
[Modified by GrandSportC3, 10:18 PM 1/20/2003]
Old 01-21-2003, 12:16 AM
71roadster
71roadster's Avatar
Olivier
Hows about measuring your driveshaft length for me??? Your the only one I know who has the mark williams yoke. It looks like the Fortes yoke is a little longer than the Mark Williams job. If I can get my driveshaft cut this week, I can put the engine in on saturday :smash: :smash: :smash:
Thanks
Chris
To Tremec 3550 and TKO owners.....
Quick Reply: Tremec 3550 and TKO owners.....
