EFI Accel Guys - Need to pick your brains
Old 01-20-2003, 08:54 AM
Fevre
Fevre's Avatar
Default EFI Accel Guys - Need to pick your brains
Just got an 89 Formula with DFI 6.32 and I know a few of you have run it. I have some questions regarding programing it and want to see if I can get some questions answered. Figured I'd start here with people I know before moving to other CF Forums and other sites.
Couple main questions:
Is the LT4 hot cam too radical to run in closed loop at idle?
At what rpm should I have the torque conv locking at? (Vigilante 2400 stall)
If you don't mind I like to ask more but figure we can exchange e-mails if that is easier.
Also any recomended sites would be helpfull.
Thanks
Old 01-20-2003, 08:58 AM
PatsLs1vette
PatsLs1vette's Avatar
Default Re: EFI Accel Guys - Need to pick your brains (Fevre)
http://www.thirdgen.org/techbb2/foru...89b&forumid=18
also try the c-4 section in tech on this forum.
Old 01-20-2003, 09:10 AM
Fevre
Fevre's Avatar
Default Re: EFI Accel Guys - Need to pick your brains (patsnitrovette)
Thanks Pat
I got the car from a moderator over at thirdgen and didn't want to have my first post be questioning his set up. :)
Figured i move the c4 section after seeing what guys here have to say.
BTW What vac are you getting from your hot cam? Seems he said he was getting over 16 at idle which should be high enough for closed loop operation. It is spitting out a lot of fumes at idle and will sputter after a while so I am guessing he has the open loop idle set to high.
Old 01-20-2003, 09:21 AM
DTE Powertrain
Collections Hold
DTE Powertrain's Avatar
Fevre-
Give me a call at the shop and I'll walk you through a couple of tables to get you started. 260-407-5455 Accel DFI is easy-peasy. We found 134 HP in a clients car with just calibration alone on his 1948 Ford Anglia w/ a BDS blown 355 SBC.
Regards,
Phil Rickard, President/Co-owner
Dunotech Engineering Inc.
Old 01-20-2003, 09:29 AM
Fevre
Fevre's Avatar
Default Re: EFI Accel Guys - Need to pick your brains (DynoTech Engineering)
Thanks Phil
Going into my office between 10 and 2, would that be a good time?
Can't beat the forum for friendly help! :cheers:
Old 01-20-2003, 12:37 PM
Fevre
Fevre's Avatar
TTT with correction: 2700 stall
Old 01-20-2003, 11:34 PM
DTE Powertrain
Collections Hold
Sure Fevre, anytime. I'm always here.
Regards,
Phil
Old 01-21-2003, 04:19 AM
Fevre
Fevre's Avatar
Kept getting busy signal yesterday, I'll try again today
Thanks
To EFI Accel Guys - Need to pick your brains
Quick Reply: EFI Accel Guys - Need to pick your brains
