Any way to keep chrome headers from turning blue?
Re: Any way to keep chrome headers from turning blue? (KBlanke)
Chrome won't last long on headers. Mine was gone in a little over a year. I think next time I will go Jet Hot..
Chris :flag
Chris :flag
St. Jude Donor '09
I feel your pain :( I learned to live with the disscoloration of the tubes near the heads until the rest of the header all the way to the sidetube took on a gold tint :U Off to Jet-Hot they went...not as :cool: as chrome but bulletproof :smash:
[Modified by yellow 72, 9:24 PM 1/19/2003]
Bluing of the tubes near the heads is normal with chrome but it doesn't diminish it's protective qualities. The chome isn't burning off, it's just changing color. My headers have been on the car for 8 years and no sign of rust or corrosion. They're blued within about 18" of the heads but the chrome still looks like new beyond that point.
Re: Any way to keep chrome headers from turning blue? (QuickVet)
There's not a lot you can do about it. As stated above, the chrome is still OK. I've had this problem with my bike for years. The only way I know of to prevent the blueing is to insert a long coil of thick (1/8") copper wire inside each pipe. This carries the heat away & dissipates it more evenly, but messes up the flow characteristics, so some people used to wind it around the outside of the pipes (a lot of Classic racers did that). That also stops or delays the blueing, but looks horrible & is a good way to promote rust. Big bore pipes will reduce discoloration, but messing up your power characteristics is a bit extreme just to prevent pipes from blueing! There's a metal polish called Solvol Autosol which will remove the blue after a lot of "elbow grease". After using it the area that was blue looks a bit like silver with mottled patterns in it & the polish is abrasive, so you can wear through the chrome (will take a long time to go through it, but I've known people that have). I just leave mine alone, people can then see its used in anger & not just used as an ornament :D
:cheers:
:cheers:
Re: Any way to keep chrome headers from turning blue? ('79ProwlerOrange)
dosent it go gold if your running to rich?
