Holding an '82 transmission in 1st gear
Help! Does any forum-members have ideas on modifying the shifter on my '82 Corvette? I can't locate 1st gear with the shifter. The indicator reads, top-to-bottom: P R N D 3 2. there's not even a '1' LISTED on the shift indicator :confused: Pulling the lever ALL the way back is still just '2nd' gear, I think. I don't wanna go :smash: this car up; it is too nice to cut & gut :D . I took this car to the strip, and couldn't hold it in 1st gear, making the blinding 15.90 @ 86 MPH passes even MORE difficult to achieve :mad any help before I go :crazy: is appreciated. :) :lol: :cheers: :D ;)
Re: Holding an '82 transmission in 1st gear (Glensgages)
You could grind the shifter so you can pull it back further, that way you can engage 1st.
On the right side in this pic is where the grinding needs to take place.
If you want to have to use the **** to free the selection for 1st you have to grind it so it's a little lower than where the key is in the pic here.
Another thing you can do, I rigged it so that the key (or tab) does not go back into the upper position (by spring pressure), this way you can mash through all the fwd gears without having to press the **** (something I found very irritating)
I think I read somewhere that the 350 -> 700 conversion kit has the correct shifter/cable combo to allow you to select 1st. I'm not 100% sure though.
Marck
[Modified by Twin_Turbo, 7:26 PM 1/19/2003]
Marck
Cruise-In III Veteran
:yesnod: Twinnie has it right.. you can grind a notch in there for it.
I've actually managed to get 1st by pushing the button all the way in and literally yanking (not REAL hard) the shifter all the way back. Next time I rip apart my console I'll probably grind the notch though.
