let"s try this again!
Okay, just installed new pressure plate & clutch, the problem now is I cannot get the trans to shift into 1st gear, just get grinding noise. I"ve been through the adjustment procedure for the clutch several times over, playing with more & less throw-out, but still no 1st gear. When installing the shifter to trans. rods I had to turn one around because it was previously installed backwards. Any help would really make my day! Thanks :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :mad
Re: let"s try this again! (vettedreams)
turn it back around!
:lol: i am HALF kidding...but hey...if it worked before........?
actually you may half to readjust it if you turned it around...
did you go thru the shifter linkage adjustment procedure?
[Modified by SIGNGUY, 6:02 PM 1/19/2003]
Re: let"s try this again! (SIGNGUY)
I now what you mean, It just looks right, the right way, and no I haven"t gone through the shifter linkage adj. because I don"t know how, wish someone would tell me :thumbs: :D
