Thinking about switching to an M-21
Senior Member since 1492
I have an M-20 now but have read that the input shafts may be different? :confused: 26 spline, 10 spline? :confused: Why the difference? I guess I can't tell which I need with the tranny in the car? :D
Re: Thinking about switching to an M-21 (1970 Stingray)
The 26 spline shaft came in 71. The 71 and later transmissions all had 26 splines and the larger 32 output shaft. I have and M20 with a 26 input and 32 output. The early M21 had the 10 spline input as did early M20 trans.
You might consider a Super T-10, Richmond has two boxes with the best of both worlds a lower 1st gear (than a M-21) for take off and a second and third that are close ratio about the same as the M-21
...redvetracr
...redvetracr
Re: Thinking about switching to an M-21 (Flareside)
The M21 is considered stronger,
redvetracer---you have mail.
Len,
Whoever told ya that all bigblocks came with a M21 is mistaken. My 70 came from the factory with a LS5 and was equipped with a M20.
Keith
Keith
Re: Thinking about switching to an M-21 (Gordonm)
Muncie challanged & deficient! :D
[Modified by 1970 Stingray, 6:29 PM 1/19/2003]
:cool: :cool: :cheers:
I have the OEM M20 also (came stock on BB AC cars). As far as I know, there is no diff between the M20 and M21 as far as strength goes (the M22 is another matter), just the ratios of the lower gears is different. I think the M20 is better because it has larger gear ratios in 1st and 2nd which is better for low end pull for the strip or street.
Mark69BB is right. If you have 3:90,4:11,4:56 gears the close ratio (M-21) is great. On the street with high gears, 3:08,3:36, 3:55 the wide ratio (M-20) works best. There is no strength differance between a M-20 and M-21.
Chuck D
Chuck D
