Brodix Vs. AFR
Old 01-18-2003, 06:56 PM
garagedweller2
garagedweller2's Avatar
Default Brodix Vs. AFR
In BBCs and SBCs, which will flow better?
Old 01-18-2003, 07:35 PM
QuickVet
QuickVet's Avatar
Default Re: Brodix Vs. AFR (garagedweller2)
I have heard that the flow rating on AFR heads is :bs
I think im going to go with Dart when I get the cash
Old 01-18-2003, 08:41 PM
81vette
81vette's Avatar
Click on the link below. At the bottom of the page are the flow numbers for most of the heads you'd likely to be interested in.
http://www.chevyhiperformance.com/techarticles/41598/
From the Chevy Hi Performance website: "The idea behind this effort was to use one flow bench to test as many small-block and big-block Chevy cylinder heads as possible. By using one flow bench and the same test procedure, we eliminated many of the variables that exist between different benches and operators. All the tests were performed at Westech Performance Group by John Baechtel and Steve Brule using a SuperFlow 600 computerized flow bench. We tested each head not only for intake and exhaust flow at 28 inches of water, but also measured each combustion chamber and intake port for actual volume."
mark
[Modified by 81vette, 7:44 PM 1/18/2003]
Old 01-18-2003, 08:55 PM
'79ProwlerOrange
'79ProwlerOrange's Avatar
Default Re: Brodix Vs. AFR (81vette)
Damn! AFR195s wernt tested. thats what i was aiming for.
Old 01-18-2003, 09:03 PM
81vette
81vette's Avatar
Default Re: Brodix Vs. AFR ('79ProwlerOrange)
I think their links may be messed up. Click on the Category 3 link. The 190 AFR's are there, and they about the same as the 195's. I think the difference is the 195 is designed for a Victor Jr. type intake.
mark
Old 01-18-2003, 09:05 PM
A C
A C's Avatar
Cruise-In II Veteran
Make sure you compare apples to apples. You have to compare the same runner size and also if one head is a CNC'ed head, the other one should be too. I know Brodix now offers a CNC line.
AC
Old 01-18-2003, 09:33 PM
'79ProwlerOrange
Default Re: Brodix Vs. AFR (A C)
sweet. im sticking with my decisions for AFRs. :smash:
Old 01-18-2003, 11:42 PM
garagedweller2
Sorry!
That was 2 questions (or 1 with 2 parts)
In Small Blocks, which flow better?
In Big Blocks, which flow better?
Old 01-19-2003, 12:38 AM
jerryjfunk
jerryjfunk's Avatar
Default Re: Brodix Vs. AFR (QuickVet)
"I have heard that the flow rating on AFR heads is :bs "
Did you hear that from Brodix? :lol:
Jerry
Old 01-19-2003, 09:06 AM
Pete79L82
Pete79L82's Avatar
Looking only at flow numbers is not a good way to predict the performance of a cylinder head. Port shape, floor to bowl transitions, bowl shape, combustion chamber design and plug location all play a huge role in how well a cylinder head will perform. Just making a port big to show "big" numbers on a flow bench without having good port design will slow the air volocity and cause fuel/air seperation in the runners drastically hurting performance.
My opinions are directed at small blocks because my hands on experience is building them about 50-1 to big blocks.
AFR are a fine cylinder for the street and for the money. But they are not in the same league as a Brodix or Dart Pro-series or Race series. And the cylinder heads are priced accordingly.
Brodix and Dart have a much better floor and short wall design over comprable AFR heads. This help keep air/fuel suspension at its peak. They also have a better chamber design over AFR promoting a better flame front and full fuel burn.
There is no one cylinder head that is the "best" for all applications. The best cylinder head choice is one that will give you the air flow CFM required for your application with the smallest runner volume. This will result in the best power curve and drivability.
For the street AFR would be a good choice of price/performance. For maximum performance/HP I would have to go Brodix or Dart.
[Modified by Pete79L82, 8:12 AM 1/19/2003]
Old 01-19-2003, 10:41 AM
QuickVet
QuickVet's Avatar
Default Re: Brodix Vs. AFR (jerryjfunk)
Jerry
sorry, every engine builder I have talked to told me this.
Old 01-19-2003, 07:24 PM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
I"m hoping the Brodix Track 1's are good, I just bought a set of fully ported babies :D ! Technology has improved over time, so any of the aftermarket heads should be an improvement over stock :yesnod: . Even my present Sportsman II's are suppose to out flow ported stock heads when they arrived in cast form ;) .
Old 01-19-2003, 07:59 PM
garagedweller2
Default Re: Brodix Vs. AFR (Pete79L82)
thanks! just what I needed :cheers:
Old 01-19-2003, 09:28 PM
jerryjfunk
jerryjfunk's Avatar
"sorry, every engine builder I have talked to told me this."
I wasn't doubting you, it was just a joke. :)
Anywho, I've heard a lot of good about AFR's, especially the 180cc.
Jerry
Old 01-20-2003, 02:00 PM
garagedweller2
The AFR is a good street head, the Brodix is among the best, but costs more(?)
To Brodix Vs. AFR
Quick Reply: Brodix Vs. AFR
