Will damage to the engine occur?
If I used a PVC on both valve covers?.....Everytime I make hard runs down the track, I find my valve covers wet with oil......is there a way to prevent this? It's not pouring oil out.....It's more like spitting oil all over the tops of the valve covers. Very messy and time consuming to clean up. :seeya Cappy
Re: Will damage to the engine occur? (8T1-7T9 BIONIC VETTE)
The engine is not really designed to have both valve covers sucking. One side needs to be a freash air source and the other to pull fumes from the engine.
Oil - I would check out the gromet on the valve covers and take a close look that the intake manifold sealing. Maybe it is not all the valve covers.
