Who makes these rims? picture attached
Cruising
The front rim... I've seen them on other vettes, are they a GM rim? Also, is there anywhere I can buy rims that look like this with different backspacing than 3.5 inch? Thanks!
Re: Who makes these rims? picture attached (gleveric)
Yes that is the original Corvette alu rim. The back spacing is 4" on that wheel and it's a 15"x8" wheel :yesnod:
Cruising
Re: Who makes these rims? picture attached (groovyjay)
doh! i must have measured wrong... i thought they were 3.5 inch backspacing and a 9 inch wide rim, unless i have a knock off? to measure the backspacing i just measured frim the back side of where the wheel lugs go, to the outside of the flang... :confused:
