Anyone got any pictures of /or using underdrive pulleys?
Did some research on the net about the mighty small block and saw these cool things. Do they really add power as advertised? What do they look like when installed. looks like they sort of stick out fro the balancer about half an inch or and then connect to the crank pulley is it? They look funny, do they do anything?
Re: Anyone got any pictures of /or using underdrive pulleys? (sharkthehunter77)
Here's what they look like mounted, can't tell you if they actually add power or not.
Re: Anyone got any pictures of /or using underdrive pulleys? (C3 Shark Tank)
I have a set of March pulleys on mine. As far as adding power, I cant remember what it felt like before the teardown last Feb.
I had an underdrive crank pulley on my 3.0 V6 Ranger.
It probably added a couple HP to the seat o the pants meter, but the biggest difference was at higher RPMs the engine would rev faster (less drag).
Was it worth the $65? I doubt it. The guy who bought my truck took it off (and it was a pain to put on)...
