Standard Rear Axle Ratios for 1975 L-48 and L-82 Automatics???
Does anyone know what the standard rear axle ratios were for the 1975 L-48 and L-82 automatics? Were they different from the manual transmission cars? Thanks for any info you may be able to provide!
Ed
Ed
Re: Standard Rear Axle Ratios for 1975 L-48 and L-82 Automatics??? (C5XTASY)
I think all the TH400s in 75 had 3.08 unless optioned otherwise.
:seeya
:seeya
Re: Standard Rear Axle Ratios for 1975 L-48 and L-82 Automatics??? (NHvette)
:seeya
:seeya
Ed
Re: Standard Rear Axle Ratios for 1975 L-48 and L-82 Automatics??? (76 Red)
My '75 auto is 3.08:1. The way to tell for sure is to check the code on the bottom of the differential. I think that 3.08 posi is "AW". Can't remember if I had to remove the mud shield thingy to read that or not...
I am not sure for '75, but the ratios for 73 were 3.08 for the L48 auto and 3.55 for the L82 auto. Optional for the L48/auto was 3.36 and for the L82/auto was 3.70. But again this was for 73.
tom
tom
My sources show codes for 1975 as:
AA= 3.55:1 posi
AB= 3.70:1 posi
AC= 4.11:1 posi
AY= 2.73:1 posi
AW= 3.08:1 posi
AX= 3.36:1 posi
LR= 3.36:1 posi
Hope it helps :seeya
AA= 3.55:1 posi
AB= 3.70:1 posi
AC= 4.11:1 posi
AY= 2.73:1 posi
AW= 3.08:1 posi
AX= 3.36:1 posi
LR= 3.36:1 posi
Re: Standard Rear Axle Ratios for 1975 L-48 and L-82 Automatics??? (page62)
A little off topic...but wasn't the L82 pretty rare in 1975 due to emissions problems?
My 1975 L-82 Coupe has the "standard" AX 3.36 ratio. The 3.55s were the "optional" ratio with the Turbo 400 transmission. :yesnod:
