Belts for underdriven March Pulleys??
Senior Member since 1492
For you guys using the underdriven --not the serpentine, March Pulleys, where are you getting the belts? Do you have numbers?
Thanks
Len
Thanks
Len
Re: Belts for underdriven March Pulleys?? (Michael Tucker)
I think I'm going to run a two groove crank, two groove water pump and one groove alt. NO AC or PS needed. Is there a belt connecting just for the crank & water pump? How is it tensioned?
Len
Len
i do at home if nobody answers i will look for them you need all three?
mike
mike
Re: Belts for underdriven March Pulleys?? (1970 Stingray)
I think my PS was a 33.5 and the ALT was a 55, not really sure but I can check in the morning when I get home. The best thing for you to do is put the pulleys on, cut an old belt and use that to measure the distance of the new one, put a mark on the belt and use a tape measure to find how many inches you need. Just tell the auto parts guy you need a XX inch belt.
this is hot off the belts
all are GoodYear Gatorback
PS 15346 matchmaker 11AV0865
ALT 15525 11AV1320
AC 15565 11AV1420
if you do end up going with one belt make sure you don't overtighten it and you should be fine. there are lots of cars out there with no AC
hope this helps
mike
edit: i should add that this is with all three pulleys crank pump and alt :)
[Modified by Michael Tucker, 12:36 AM 1/16/2003]
ALT 15525 11AV1320
AC 15565 11AV1420
hope this helps
mike
I just saw this---you guys have SB...this is for a BB.
1970 Stingray your killing me. do you know how hard it was to get the ps numbers :)
when GM starts selling the new 572 i will be able to give you your answer but only for the one bely system
i think they should just let me buy it now so i can have it in for the 2003 hot rod power tour :smash:
good luck on your quest
mike
mike
Yeah, I'm sorry. I should've mentioned the BB part in the title. That's what happens when I post after a 15hr day. :(
funny i worked 16 hrs yesterday and i was back here at 0615 this morning :U the good thing is that my check this friday is going to have 66.75 hrs ot :D
mike
mike
