Oil temperature sender source.
Well I'm in the area of the oil temperator/pressure sensors (which aren't working.)
So I figured I might check them out, replace them.
Anyone find a better source for these?
The 'zone has the oil pressure switch, but not the temperature sensor.
Napa has both, but they want $20+ for them.
Ecklers want even more...
Any other places to check?
Sorry - wrong button, no poll here...
[Modified by adam, 1:01 PM 1/15/2003]
Re: Oil temperature sender source. (Ki m Le)
This is from napa... It looks similar to what is in my car (when I'm underneat
it and looking at it in the block.
http://www.napaonline.com/cgi-bin/nc...MAGE=77401.jpg
We'll see if you see it...
Otherwise search for 'oil temp sensor'
Re: Oil temperature sender source. (adam)
This is the GM oil temp sensor. I do not recall the cost but it might be worth a try. And you will get an "accurate" reading when you go with an original rather than a generic.
Re: Oil temperature sender source. (paul79)
Thanks Paul;
I wrote that number down, but thought it was a Jegs number.
Hmmm,
Has anyone used {Non-supporting vendor}.com ?
#25036292 - list price $31.78 our price $15.89 :eek:
Shipping is $8, but that is quite a difference... I'll check the dealership tomorrow
to see what they would charge.
