What should I use to bond L-88 cold air to my hood?
Old 01-15-2003, 08:43 AM
Corey_68
Corey_68's Avatar
Default What should I use to bond L-88 cold air to my hood?
Title says it all, what should I use to bond it to the underside of the hood?
Old 01-15-2003, 09:13 AM
Solidlifters
Default Re: What should I use to bond L-88 cold air to my hood? (Corey 68)
Corvette panel strip adhesive by Fiberglass Evercoat is an excellent product. I think 880 is the part number in gallons for the NON SMC type fiberglass, but it's available in quarts also. It also makes an excellent filler for fiberglass. It's much harder than Bondo and supposedly the expansion coefficient is very similar to the PM type glass.
Fiberglass evercoat also manufacters a dual product for both SMC and PM glass, but I prefer the characteristics of the PM specific product.
I'm assuming you're going to remove the hood and turn it upside down. It will need to be supported level during bonding. With the added strength of the L88 box, if the hood is in a crooked position, it will likely have some fit issues when it's reinstalled, such as a rear corner slightly high. You will also need to rough up the two surfaces where the bonding will occur so the adhesive will stick, and of course since the hood may have been oily underneat it will need to be clean before sanding.
What kind of hood is it that you're putting the box under?
[Modified by Solidlifters, 2:17 PM 1/15/2003]
Old 01-15-2003, 12:55 PM
Corey_68
Corey_68's Avatar
Default Re: What should I use to bond L-88 cold air to my hood? (Solidlifters)
I went with Vanacor Corvette's AKA "Ecklers".
Vanacor builds all of Eckler's fibergtlass parts.
:cheers:
[Modified by Corey 68, 11:56 AM 1/15/2003]
Old 01-15-2003, 01:57 PM
zwede
zwede's Avatar
I used regular epoxy to bond it and then filled the crack with fiberglass resin. Maybe not the "correct" way, but it is on there very solidly!
Old 01-15-2003, 02:12 PM
Bamavette74
Bamavette74's Avatar
Default Re: What should I use to bond L-88 cold air to my hood? (zwede)
I was informed, via a post on here some time ago, that a product known as 3M 5200 is the way to go when it comes to bonding body panels and the like. It is readily available at Home Depot and comes in the convenience of a caulk tube. I plan to use it to re-affix some body panel issues on mine.
Just a thought...
Old 01-15-2003, 02:29 PM
Corey_68
Corey_68's Avatar
Default Re: What should I use to bond L-88 cold air to my hood? (Bamavette74)
Cool, thanks for the info guys. :cheers:
Old 01-15-2003, 04:26 PM
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
:withstupid: :iagree:
Old 01-15-2003, 06:58 PM
Solidlifters
Default Re: What should I use to bond L-88 cold air to my hood? (1970 Stingray)
5200 3M is an excellent product with extreme adhesive strength. When used on boats, which is what it was designed for, it is almost impossible to remove without their special solvent. There are a couple of differences in Corvettes, and the major reason I've been hesitant to experiment with new products. First of all, I've been using the 880 Fiberglass Evercoat product for over 25 years and have never had a failure with anything I used it for, so that makes it difficult to change. A chemical engineer told me way back then that the expansion co efficient of this product was as similar to that of the press moulded fiberglass as could be done outside of resin and mat, so as temperatures change there are less likely to be stress cracks and/or shrinkage. This same engineer stressed that common Bondo should never be used on a Corvette for the same reason, because the properties were different enough to cause problems. In years of fooling with them, I've seen countless problems when regular bondo type products were used. As far as the new stuff, including the 5200, I don't know about expansion/contraction/age shrinkage with any of these, and just haven't been willing to experiment away from the old stuff that I know works. The new mixing tube 3M stuff works well on the later stuff, but for now at least, I'm sticking with the old way on mine.
Old 01-15-2003, 11:12 PM
yellow 72
yellow 72's Avatar
St. Jude Donor '09
Liquid nails construction adhesive, gap filled with black urethane caulk :smash:
[Modified by yellow 72, 11:13 PM 1/15/2003]
Old 01-16-2003, 01:32 AM
paintdaddy
paintdaddy's Avatar
:cheers:
[Modified by Corey 68, 11:56 AM 1/15/2003][/QUOTE]I dont think they are the same.Ecklers makes their own glass.Vanacors a nice guy but his parts dont fit half of the time.Ecklers is higher in price but always fit better.I would also use epoxy ,just grind it good on both sides :seeya
To What should I use to bond L-88 cold air to my hood?
Quick Reply: What should I use to bond L-88 cold air to my hood?
