Anyone Used these Fel-Pro Intake Gaskets?
Re: Anyone Used these Fel-Pro Intake Gaskets? (paul79)
:yesnod: it's 4:24 am here, damn kid upstairs is crying again.. I hate appartments :( So, instead of lying wide awake I figured I'd go do something usefull and maybe I'll fall asleep behind the KB :D
I used these (don't remember the exact p/n) last time I pulled the intake:
http://store.summitracing.com/partde...57#largerimage
I like them so much, I'm using them again...
Re: Anyone Used these Fel-Pro Intake Gaskets? (rainman69)
Of course...my intake ports are large enough to fall into...So, the larger intake gaskets are a must.
But, I really like the sealing capability of the blue stuff around the ports...
Paul79,
You might also take a look at Fel-Pro 1256. They were recommended in an NCRS article on aftermarket gaskets (Greg Ellis).
The Fel-Pro 1204 and 1205 gaskets have blocked exhaust crossovers. They may not be appropriate for your location, as the exhaust crossover is supposed to aid cold weather driveability.
Re: Anyone Used these Fel-Pro Intake Gaskets? (mapman)
Ditto on the Fel-Pro Performance line-up. The 1204 is actually cheaper than the normal Fel-Pro set: http://store.summitracing.com/partdetail.asp?part=5765
I purchased MS 90314-2 today. I need that crossover hole. Hopefully they will be as good as the 1256.
