i would like to know your pressure plate thickness...please
i dont know if you recall but i was thinking that i had the wrong clutch because i was at the end of the ajustment rod when we installed the new motor...i asked about a longer rod...??
anyway...we pulled the trany tonight and removed the clutch...
when lying flat on the table...from the table surface to the tops of the fingers
my pressure plate is 2 7/16" tall...
the throw out bearing is 1 1/4" tall...
is this correct? im hoping that its a tad short...
im headin to the parts store in the mornin to look into the possibility that its the wrong part...
i was just curious if any of you happen to know...
Re: i would like to know your pressure plate thickness...please (SIGNGUY)
nobody huh? i figured somebody would have one lying around and could mesure it for me...
oh well...its off to the parts store this morning to see if we can figure it out...
thanx anyway...
thanx anyway...
