Paging WA 2 FST
Paging WA 2 FST
Please tell me the wheel tire combo on you 69. Brand? Any rubbing, mods to install, or adapters. Man I like the look. Thanks Thad :D
Re: Paging WA 2 FST (TNT)
Wheels are Boyd Coddington Timeless 5. They are billet aluminum. Fronts are 17x8 with 4" BS...running 245/45 tires. Rears are 17x9.5 w/ 4.75" BS...running 285/40 tires. You do NOT need any spacer or adapters for these wheels to clear the calipers, so you don't have to figure anything else into the equation when trying to determine total offset/backspacing. :)
No rubbing, but I have a set of VBP offset rear trailing arms, although I'm not sure I would have rubbed with the stock TA's...assuming, of course, that the e-brake cable and bracket were relocated.
Hope this helps!
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Re: Paging WA 2 FST (WA 2 FST)
Yes they are very nice I had admired them myself.
You state that you have the 17 x 9.5s in the rear with 4.75 BS and Offset TA's.Could you have used a larger wheel in the rear?
How would they have fit with 17x9.5 with 285- 40s in front?
Several have used this combo on all four. I still am not sure about it though. Do you think you could have used the 4 x 17x9.5 285-40s ?
Thanks JIM
Thanks JIM
Re: Paging WA 2 FST (PROSOUTH)
Thanks JIM
Thanks JIM
I believe I could have run another .25-.5" wide in the rear...and just run more BS (5.00-5.25")...although it would be tight on my car.
As far as the front, I was told by a number of forum members that on the '68-69 I was going to have a hard time with anything larger than 255s, so I didn't even bother measuring or trying. I have seen some with the 275/40 or even 285/40 on the front, but on some of them I've noticed reworked fenders, etc.
So really I cannot honestly answer your question with any certainty. I wish I could help here. I have not bolted the rears onto the front to see.
