How much HP can the borg warner T-10 tranny handle?
Re: How much HP can the borg warner T-10 tranny handle? (C3w4sp)
Here's a good list:
http://www.richmondgear.com/cat/supert10.html A high torque rating is what you want, torque is what snaps parts.
It should handle it if you don't race it too hard. Slicks and 5000 RPM launches are hard on trannies.
Re: How much HP can the borg warner T-10 tranny handle? (Fevre)
Fevre,
Thanks, I'm not sure I understand the chart. Is the torque figure to the far right the max torque that tranny can handle?
Thats the torque it is rated at - that doesnt mean that instant detonation of internals occurs the moment you exceed that number.
Like mentioned before - the big issue is if you hook - if you dont hook - the tranney will support just about any torque you care to throw at it - you put on slicks and run it hard with clutch dumps and you may want to consider the number on the chart indicated.
