Control Arm Bushing removal in Raleigh
Looking for someone that knows what their doing with control arm bushings in Raleigh. I'll want the old ones removed and new ones installed after painting. Can anybody recomend a shop or individual that knows how to do this correctly?
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Control Arm Bushing removal in Raleigh (CHEESERAL)
Try contacting Tom454, he is the super guru in the Raleigh area, if he doesn't know someone who can do the job, then the job probably can't be done.
I would check with Boyette's in downtown Raleigh or check with Chris on whether he thinks Tiger can do this for you. Haven't heard from Tom454 in a while but last I did, he had alot of things in the works and his time was tight.
Cheeseral/Chuck:
If you're replacing w/ polyurethane CA bushings ... polys are rather easy to do yourself ... no press needed. Myself & many others here have done poly ... happy to explain if needed.
However, if you're replacing w/ RUBBER CA bushing (as OE) ... then I'd follow the others' suggestions for a local shop.
