REPAIRED VACCUME DOORS FOR DEF/HEAT COOL RE-CYCLE ALL WORK!
I WANTED TO THAK THE FORUM- AND GREAT PEOPLE- THE OTHER DAT I POSTED IF ANY ONE KNEW THE FUNCTIONS OF THE HEAT -A/C DIAPHRAMS-------I GOT A WEB PAGE FROM FELLOW VETTE GUY -- AND WITH SOME JUMPERING FROM VACCUME SOURCE TO EACH LOAD-THEY ALL WORKED-THE PROBLEM WAS IN THE ''CLIMATE CONTROL ROTARY SWITCH---9 PORT''-19.5- HOPEFULLY BY REPARING THIS AND INSTALLING THE LARGER SQUIRRELL CAGE AND SPACER( IUSED THE STOVE TOP CAP) I HOPE TO GET BETTER AIR FLOW- WELL AT LEAST I KNOW WHEN I PUT IT TO HEAT ITLL COME OUT BY MY FEET- AND DEFROST AT THE WINDSHIELD-INSTEAD OF EVERYWARE ALL OVER
Re: REPAIRED VACCUME DOORS FOR DEF/HEAT COOL RE-CYCLE ALL WORK! (carl a)
I went through the same thing last spring ,the new fan and spacer ,new vaccum lines and now I have real air,its the little things that matter sometimes make all the differance :hurray:
