Tv problem solved,of intrest to Edelbrock Q jet users
When I went to od it seemed like I didn`t have enough carb linkage travel at max tv for the 4 barrel to open.After much work on the valve body and trying to adjust the tv with no luck :cuss I had to just walk away.So this morning I checked the linkage travel to secondary contact on my stock carb,3/4"huh.Checked it on the #1902 Edelbrock 1.5".double huh!Did some "fine tuning" on the linkage contact points to get 3/4" travel and now I have a 4 barrel again. :D Just proves that you better check every thing when changing parts.Boy do I feel stupid or what. :banghead: Any way it`s time for a :steering: Joe
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Enjoy the 4 BBL power and the OD cruise !!! :auto:
