AC Conversion Question
I'm converting my AC to a R-134 using the OE condenser and evaporator coils as well as a Sanden type compressor. The evap coil must have the upper refrigerant pipe modified to connect straight forward (vs. OE curved and down). Since my engine is installed and I have headers, removing the evap coil is not an option.
So, the question is - how do I modify the upper connecting pipe? Cut with a hack saw and let the AC shop figure it out? Cut with a plumbers copper tube cutter and flare the end? Wait and drive it to the AC shop and let them torch it off and weld/solder a threaded connection?
Your input please.
[Modified by flynhi, 5:46 PM 1/10/2003]
Your input please.
Re: AC Conversion Question (flynhi)
The evap coil msut have the upper refrigerant pipe modified to connect straight forward (VS curved and down).
Also, I've read that when you use 134, the expansion valve should be recalibrated to make the system as efficient as it can be and hence get the outlet temps as low as possible. Have you heard or looked into the expansion valve? From what I can tell it's part of the evaporator in our cars.
When I had my original A/C manifold re-hosed with barrier hose for 134a, Hal's Auto Air in Sacramento cut off the original ends and TIG welded on the new barbed ends suitable for the r134a hose. I don't see why a competent shop couldn't do the same for your evap, even if it's on the car. Just clear out around it. otherwise, weld up an adaptor. Be kinda bubba, but it should work.
Hans
Hans
I am running R134a in my 69 with all of the stock original parts. I just changed to the ester oil. You just cannot overcharge the system with R134a. It takes about 60% of the R12 charge. Mine works great even in Florida's hot humid summers.
Re: AC Conversion Question (74-Roadster)
It's the STV that needs to be adjusted, not the expansion valve. I took a chance and left my STV alone replaced the expansion valve and it works killer. I also re-sealed the compressor, new dryer, replaced the o-rings and added the right oil.
Hans
Hans
Re: AC Conversion Question (Wrencher)
Wrencher,
Thanks for your response. Can you see any reason why I can't cut it now to get the turn down out of the way as long as I tape off the end to keep crud out?
flynhi, leave that pipe alone, as the evap itself if really really really weak inside there and will NOT stand much if any flex with you working on that pipe....cutting it will allmost certainly break the evap coils....the ends where that pipe goes in is weak corrugated aluminum....
GENE
GENE
