Quick question! (Suspension)
I would like as much adjustibility in my rear ride height as possible. If I put 10 inch spring bolts in, I know I will be able to acheive a much lower height, but how high can I get? Would I need to buy both 8" and 10" to have the full range of adjustment, or do the 10 inchers have twice the thread?
Thanks,
Chris
Thanks,
Chris
Re: Quick question! (RUXperienced)
You don't have to use the bolts from a kit.
Go to a good hardware store and look through the bins for a hardened
bolt of the proper size. There may be even a full threaded one out there.
CFOT Attention Whore
:withstupid: <--just glad to see it back :D
i currently have grade 8 1/2"x10 bolts in my rear spring. i use a jam nut and nyloc and have 1"+ adjustability. mine is not fully threaded though. got all the hardware at a local bolt store for about $8 for both sides :cool:
:cheers:
:cheers:
Re: Quick question! (clutchdust)
Could not find Grade 8 (or 5) of the correct size at any local hardware stores (Ace, HomeDepot) A tractor supply store came closer, but still only Grade 5 6inch partially threaded. According to my dad, this size of bolt would be hard to find, so what's up with your hardware stores? I'd rather not special order a full box just to get 2!
Re: Quick question! (cheese)
you might also try an extensive machine shop, one who fabricates and does all types of work. we have a one in town here who actually has a "fasteners" room. all kinds of bolts,nuts,washers, etc. i can usually find what i need.
