steering replacement question
Old 01-09-2003, 03:05 PM
TJRed76
TJRed76's Avatar
Default steering replacement question
A friend of mine just went through his entire power steering system and replaced the pump, valve, cylinder, and hoses.
Now his car will turn to the right just fine, but will not turn all the way to the left.
He says that the hoses are not binding on anything. What else could it be?
:nonod:
Old 01-09-2003, 03:09 PM
norvalwilhelm
norvalwilhelm's Avatar
Default Re: steering replacement question (TJRed76)
Does he know how to balance the power steering control valve?
Old 01-10-2003, 12:39 PM
TJRed76
TJRed76's Avatar
Default Re: steering replacement question (norvalwilhelm)
No, and neither do I.
Can you give a description, or give me an url that I can read about it at?
Thanks!
Old 01-10-2003, 02:21 PM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
Go to http://www.corvettefaq.com and look under Steering. Download the following paper entitled: Control Valve Replace and Balance Instructions
This should help.
Old 01-10-2003, 05:07 PM
TJRed76
TJRed76's Avatar
Default Re: steering replacement question (Jim Shea)
Thanks, I will pass this info. on to him and see if it does the trick.
TJ
To steering replacement question
Quick Reply: steering replacement question
