C3 drag racers. Whats your ET/mph?
Old 01-09-2003, 11:06 AM
WillRace4Food
WillRace4Food's Avatar
Default C3 drag racers. Whats your ET/mph?
I'm new here so just trying to get a hold on what people around here are running. My times are in my sig.
Also..anyone from Louisiana..baton rouge area that likes to race their vette?
Tim
Old 01-09-2003, 01:47 PM
Gordonm
Gordonm's Avatar
Default Re: C3 drag racers. Whats your ET/mph? (WillRace4Food)
That is a pretty good 60 foot time. I have a similar motor setup but my car no way hooks like yours. The best I have done is 12.7 at 110 wit ha 1.97 60 foot time. Street tires. Your car really hooks to be in the 11s with a 113 trap speed. Thats :cool:
[Modified by Gordonm, 1:47 PM 1/9/2003]
Old 01-09-2003, 01:54 PM
LAvetteman
LAvetteman's Avatar
St. Jude Contributor
Howdy neighbor, currently my best is in my sig. I like to race every now and again. Haven't raced in BR yet. Let me know if you want get together with the rest of the Lousiana crazies.
Old 01-09-2003, 02:12 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
My best so far was 12.190 @ 115.04 mph.. My best mph was 115.5 mph and my best 60' time was 1.676... (not at the same run)
All the information is also in my sig...
:cheers:
Olivier
Old 01-09-2003, 02:15 PM
GrandSportC3
Hey WillRace4Food,
do you run a stock rear end with those 60' times?? I'm worried about breaking mine (I might actually have broken already something in my rear end)... and I'm usually only running 1.70's 60' time.. (once I was in the 1.60's)
:cheers:
Olivier
Old 01-09-2003, 02:18 PM
Maurice
Maurice's Avatar
I have issues shifting usually, but my best is 12.3 and my best MPH is 115.45, my best 60' is 1.72.
Old 01-09-2003, 04:51 PM
WillRace4Food
Default Re: C3 drag racers. Whats your ET/mph? (GrandSportC3)
gordonm. I haven't done anyting to the suspension. I actually have road race springs on front and back. I run a 275/50 drag radial..stall it up to about 2500..and flat foot it out of the hole. The car just squats and goes. I run about 18 lbs in the tires. I'm usually on a pretty descent track to that helps too.
71...I'm always up for racing...lol. My vette is down right now..some kind of crazy ignition or fire problem I'm trying to work out. I thought it jumped time at first...pulled the motor down..everything fine..plugs/wires/coil..all replaced..no change..thought maybe it wasn't getting fuel..changing pump..no change..I'm gonna put a new dist. in it and see what happens. Good to see some La. guys like to use their vette.
Grandsport...yea..stock rear end. I have Spicer black u-joints in it but everything else is stock...well..besides the strange 3.90 gears. You manual guys are much harder on the rear end since I can preload it at the line. YOu guys just shock them ..thats what breaks em. What posi are you running? May be worth a locker if you can live with it on the street(do they make those for vettes?) Iknow all about that. My other car is a 95 formula 6 speed(in sig). I put a 9" in that thing to handle launching but have managed 1.49 60's in it. With 115 you guys are just some good shifts away from the 11s. Its a skill and takes practice. Here are 2 of my runs in my other car..shifting away. http://www.ipsb.net/herringt/video/TimH1108.mpg
http://www.ipsb.net/herringt/video/timH1114.mpg
Bang those gears guys..go 11s and get kicked off the track :yesnod:
Good to see some fast cars here.
Tim
[Modified by WillRace4Food, 9:54 PM 1/9/2003]
[Modified by WillRace4Food, 9:56 PM 1/9/2003]
[Modified by WillRace4Food, 9:57 PM 1/9/2003]
Old 01-09-2003, 05:35 PM
bence13_33
bence13_33's Avatar
My best run was a 12.40 @ 116mph
My best 60' was a 2.08 :U
With some modifications in the very near future I am hoping to hit mid 11s.
Old 01-09-2003, 06:02 PM
LAvetteman
LAvetteman's Avatar
Tim
Oh you too, I am having a problem right now with ignition as well, sputtering at around 3000 RPM. Must be something in the air.
:lol:
Old 01-09-2003, 06:32 PM
Corey_68
Corey_68's Avatar
Default Re: C3 drag racers. Whats your ET/mph? (71,454,4spd)
Hope to have mine up and running soon. I'm curious to see what times she turns. :cheers:
Old 01-09-2003, 07:04 PM
GrandSportC3
Default Re: C3 drag racers. Whats your ET/mph? (bence13_33)
Get some offset trailing arms and run 325/50R15 BFG Drag Radials and you won't have anymore traction problems.. That's the setup that I'm going to go with... I'm sure that - if you hook up right - you should be in the 11.70 - 11.80 range...
:cheers:
Olivier
Old 01-09-2003, 07:15 PM
GrandSportC3
[QUOTE]Grandsport...yea..stock rear end. I have Spicer black u-joints in it but everything else is stock...[/quick]
That sounds exactly like my setup... I use solid Spicers and a stock rear end
I'm running 3.55 rear gears. (The gears on my tranny are 3.27 1.98 1.34 1.00 .68) (Tremec TKO 5-speed)
dunno..
I'm thinking in upgrading the rear end with stronger parts.. If I'm unable to fix my current problems with the rear - I will have the rear end rebuild with stronger parts. I spoke with Van Steel and I told them what kind of 60' times I'm running and they say that they can rebuild my rear end so that I can run those kind of 60' times without breaking it... My mph also indicated a solid 11 secind car...
Well - I know that I'm shifting too slow (especially because the mech. clutch has a long way to depress the clutch completely). With faster shifts and a better 60' time - I'm 100% sure that I'll be in the 11's... A professional driver that would powershift would make mid 11's with my car for sure... Well - I don't have a scattershield - so it's not too wiseley to powershift...
Tim
cool videos!!!
:cheers: :cheers:
Olivier
Old 01-09-2003, 08:07 PM
Clink69
Clink69's Avatar
See my sig. Gee those Autos are hard to compete with... Mine times will improve now that I have line lock. I spin a lot...
Chris
:flag
Old 01-09-2003, 11:22 PM
ZL1powr
ZL1powr's Avatar
My best Et run was as follows:
60' 2.104
330' 5.234
1/8 7.901 @ 97.19
1000 10.088
1/4 11.912 @ 123.91
This was with 275 15 BFG Radial TA street tires and thru restrictive side pipe mufflers. Lots of finesse to hook up in 1st and 2nd.
[Modified by ZL1powr, 4:24 AM 1/10/2003]
Old 01-09-2003, 11:44 PM
DJ Dep
DJ Dep's Avatar
St. Jude Donor '05-'07
Default Re: C3 drag racers. Whats your ET/mph? (ZL1powr)
60' 2.104
330' 5.234
1/8 7.901 @ 97.19
1000 10.088
1/4 11.912 @ 123.91
Hey Jim,
Glad you posted! Saves me the effort of cut and paste ;)
Sure like to see the times with open headers and slicks :D
Dep...still looking for his ZL-1 block
Old 01-09-2003, 11:45 PM
GrandSportC3
60' 2.104
330' 5.234
1/8 7.901 @ 97.19
1000 10.088
1/4 11.912 @ 123.91
If you get some good Drag Radials - 10's are not out of the question :eek: :eek: :eek:
:cheers:
Olivier
Old 01-10-2003, 12:14 AM
jimtreber
jimtreber's Avatar
low et slip, high mph slip. The reason for the "go to tower" note was so they could chew my butt out for doing dry burnouts in the staging. Runs made with street radials and thru the mufflers.
1976, 406sb, th400, 3000stall, 4.11, nitrous
To C3 drag racers. Whats your ET/mph?
Old 01-10-2003, 12:35 AM
WillRace4Food
Default Re: C3 drag racers. Whats your ET/mph? (jimtreber)
very nice zl1. your picking up 26 mph on the top end..that thing is pullin like a mule. Get some traction and let that thing breath.
Jim...thats a big difference in MPH. I've found that when you sping hard off the line that the mph goes up but the et suffers. When you dead hook the et is better and mph goes down.
Whats the deal with all you guys on street tires... :nonod:
Old 01-10-2003, 01:16 AM
DJ Dep
DJ Dep's Avatar
:cheers:
Olivier
Hey Olivier...check his compression ratio! If he had the 12-1 of the original ZL-1 just imagine what kind oif times he would turn!!!
:smash: :smash: :smash: :smash: :smash:
Geez I gotta get me a ZL-1!!!!!! :cool:
Dep
[Modified by Dep, 12:18 AM 1/10/2003]
Old 01-10-2003, 01:20 AM
blackLS1
blackLS1's Avatar
You guys are posting awesome numbers.I cant wait to get a C3 one day.But I'll have to make do with my Z28 at the track until then.
Quick Reply: C3 drag racers. Whats your ET/mph?
