'76 SPEEDO NOISE
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
'76 SPEEDO NOISE
I have some speedo noise from the dash and am wondering what is the easiest way to lube the cable behind the dash. This is an a/c car.
[Modified by Jud Chapin, 12:45 PM 1/9/2003]
A CI-6 Car Show Winner
Re: '76 SPEEDO NOISE (Jud Chapin)
If your speedo cable is 2 piece you could get the lube in from the engine compartment where the 2 cables join. If not, I think you will have to pull the dash apart to get in there, seems awful tight any other way. Goodluck, hope this helps.
