Differential update..
On my way back home from work - I noticed some improvement.. Tomorrow (well actually today - it's almost 2 AM now) I will get some posi additive...
:cheers:
Olivier
:cheers:
Olivier
Re: Differential update.. ('79ProwlerOrange)
:cool: lube it up and find a spot for some figure 8s :cheers:
:cheers:
Olivier
Re: Differential update.. (Gordonm)
The posi additive is definitly needed for proper operation of the clutch packs. Putting it in should help it out.
:cheers:
Olivier
Re: Differential update.. (GrandSportC3)
My feeling is you will be real happy :cheers: after adding the additive and doing some 8's or a few hard right & left hand turns. Give it a couple of days to work in and :cheers: :cheers:
Re: Differential update.. (74Coupe)
:cheers:
Olivier
that probably all it is. mine started clunking too, i went in a parking lot and did some decent 8s, and i havent heard it since. i think im going to add some more lube before too long too just incase.
