anyone doing a trailing arm rebuild?
If so, does anyone have the rear bushings out? I need both pairs of outer shells and was wondering if someone has them. Mine were sos tuf they did not survive the air chisel. If you are replacing with rubber they come with the new rubber bushings but I'm going poly and will need the outer shells.
Thanks,
Marck
Thanks,
Marck
Re: anyone doing a trailing arm rebuild? (Twin_Turbo)
I think I remember seeing a brand of poly graphites with or without the outer steel sleeve. I've got my doubts that you're going to find any used ones that are useable after they're removed from a trailing arm anyway.
Marck....I rebuilt mine last year and have all the old pieces still hanging around. I replaced every bush with poly and used all new sleeves so the old shells should be still here. If the ones I have are what you're after they're yours.
[Modified by Brutus, 5:53 PM 1/9/2003]
[Modified by Brutus, 9:47 PM 1/9/2003]
Are these what you're after? All I did was drill off the head of the inner sleeve, so apart from that they are as you see them......still useable I would think.
Despite how they appear in this quick pic I just took, they are quite ok.....just grubby.
[Modified by Brutus, 10:15 PM 1/9/2003]
I have also pair of fully rebuild and painted stock trailing arms with poly bushings if someone is interested.
Re: anyone doing a trailing arm rebuild? (groovyjay)
Brutus, yes that would be them. I'd only need the outer shells, there's rubber and the inner shell and shaft stillm in those right (hard to see w/ all the dirt :) )
But.. you have new sleeves? Did they come with the poly kit or did you buy them somewhere?
Marck
[Modified by Twin_Turbo, 5:42 PM 1/9/2003]
Marck
I bought the complete kit with poly bushes and sleeves from Vette Brakes.
Let me know which way you want to go and if you want my old bits. I can post them over to you as soon as you like.
Re: anyone doing a trailing arm rebuild? (Brutus)
:hurray: :hurray: :hurray:
the search is over... I can finally start installing those bushings soon.
Thanks Bob :cheers:
Marck
Thanks Bob :cheers:
Marck
Hi Marck. I am replacing my trailing arms as we speak. I bought new trailiong arms which came with rubber bushings already installed. I am cutting them out and replacing them with poly bushings and sleeves which just arrived today from Vette Products and Brakes. They are not that expensive. Good luck, John :steering:
Re: anyone doing a trailing arm rebuild? (jdcrvt)
If I had known the poly ones I have didn't have the outer bushing I'd gone for the VB&P ones but I though, let's give CF a try and it worked [:)]
Thanks,
Paul
