A/C shutdown
A/C shutdown
I'm in the process of anengine swap on my 1979 and I'm not going to use the a/c. So what special things do I have to do after removing the compressor and hoses to preserve the system if I want it back later?
Thanks
1979 ZZ430
Thanks
1979 ZZ430
A CI-6 Car Show Winner
Re: A/C shutdown (jroyse)
I would go to your local hardware store and get an assortment of rubber corks and plug everything. This will keep out moisture and contaminates. Be sure they fit nice and tight, you won't have any problems then if you ever want to re-use the parts. Sometimes the old hoses aren't worth saving, depending on their condition (they get dry rot and start to crack). Hope this helps! :steering:
Re: A/C shutdown (Big Fish)
http://www.eastwoodco.com/aspfiles/i...1.x=35&I1.y=35
