how big is your cam lift in your 350
Old 01-08-2003, 03:46 PM
gravismaximus
gravismaximus's Avatar
Default how big is your cam lift in your 350
just a question i have for all of you, i want to see how my lift spec's compare to the rest of you. please put in intake and exhaust and why you choose that lift. :chevy
Old 01-08-2003, 03:53 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: how big is your cam lift in your 350 (gravismaximus)
Well - mine is a 383 (350 block) and my lift is .540
:cheers:
Olivier
Old 01-08-2003, 03:59 PM
PatsLs1vette
PatsLs1vette's Avatar
Default Re: how big is your cam lift in your 350 (GrandSportC3)
Mines a 60 over 350 with 487 in 510 ex zz4 roller cam.it was free :D
Old 01-08-2003, 04:01 PM
Alwyn678
Alwyn678's Avatar
.458 lift
[Modified by Alwyn678, 4:02 PM 1/8/2003]
QuickVet
QuickVet's Avatar
Default Re: how big is your cam lift in your 350 (patsnitrovette)
I have 515/515 lift :D
Old 01-08-2003, 04:03 PM
HDIronman
HDIronman's Avatar
CompCam Magnum 480/480 lift 280H grind
:steering:
Old 01-08-2003, 04:04 PM
SuprJames
SuprJames's Avatar
.525/.525 on a 383 stroker :D
Old 01-08-2003, 04:39 PM
redwingvette
Support Corvetteforum!
redwingvette's Avatar
Default Re: how big is your cam lift in your 350 (SuprJames)
Crane Cam H-266 440 intake 454 exhaust
Old 01-08-2003, 04:43 PM
WillRace4Food
WillRace4Food's Avatar
Default Re: how big is your cam lift in your 350 (redwingvette)
.560 I/E with 1.6 rockers.
Tim
Old 01-08-2003, 04:47 PM
Fevre
Fevre's Avatar
0.546 and .563 with 1.6 rockers, need to switch to 1.5 to get to .509 and .528, too much lift for my little 350 right now.
Old 01-08-2003, 05:04 PM
MasterDave
Moderator
MasterDave's Avatar
Went from 510/510 to 487/490 to 465/485 in the last two years. Looking for more torque in the 1800-5800 range. But it's not always lift, there's lotsa variables within each cam that change it charactarstics.
Old 01-08-2003, 05:13 PM
Ryan77
Ryan77's Avatar
Default Re: how big is your cam lift in your 350 (MasterDave)
.477"/.480" :cheers:
Old 01-08-2003, 05:20 PM
Ken73
Ken73's Avatar
Cruise-In III Veteran
.454"/.454" lift, .488"/.488" with 1.6:1 roller tip rockers...
Old 01-08-2003, 05:21 PM
Jason Staley
Jason Staley's Avatar
I have a .545/.545 lift cam in my ZZ4.
TedH
TedH's Avatar
I believe my single-pattern Crane Energizer 272H is rated at .450/.450" lift before multiplication by the rocker ratio.
Old 01-08-2003, 06:37 PM
gravismaximus
Default Re: how big is your cam lift in your 350 (TedH)
so mines right in the middle, good. i got a .525 .525 roller comp cam thanks for letting me now. :steering:
Old 01-08-2003, 07:43 PM
SLICKMAN
SLICKMAN's Avatar
Stock L82, 450 / 460 :D
To how big is your cam lift in your 350
Old 01-08-2003, 07:50 PM
SuperFast80
SuperFast80's Avatar
Default Re: how big is your cam lift in your 350 (SLICKMAN)
Had .454/.488 then switched to .447/.447 for more mid-range in my mild buildup. Cost about 20hp but brought the rest of it down into a more usable range.
Old 01-08-2003, 08:37 PM
SmokedTires
SmokedTires's Avatar
St. Jude Donor '05
Default Re: how big is your cam lift in your 350 (SuperFast80)
Currently .488 & .510 hyd, future 388 may have around .650 mech roller :D
Old 01-08-2003, 08:46 PM
spikezz4
spikezz4's Avatar
Intake 550; Exhaust 550. LS6's come that way.
Spike
Quick Reply: how big is your cam lift in your 350
