Stroker Oddities
Stroker Oddities
I'm still I guess getting used to the new noises of this motor. It is my first stroker ... and the engine builder says that it's bound to make noises when cold. He says that the stroker pistons are assembled with a lot more slack than the engines I'm used to bulding and that when cold, noise is normal. That combined with the roller rockers and I'm just amazed at the noise when cold.
Now the rockers I'm ok with - sounds like a solid cam and I've built & driven cars with solid cams for years. But that piston slap when cold drives me nuts! It sounds like a rod knock!
Just how normal is this noise? Is it better in warm weather?? :hat
Re: Stroker Oddities (Smokehouse69)
Forged pistons are going to make more noise that cast pistons especially when the engine is cold
And does it sound like a rod knock? :mad
Re: Stroker Oddities (SanDiegoPaul)
" He says that the stroker pistons are assembled with a lot more slack than the engines I'm used to bulding and that when cold, noise is normal."
That sounds like a bit of BS to me. Mine does not make any similar noises cold. When warm I do hear the lifters though. Mine are forged pistons..., forged everything for that matter... do you have 5.7 or 6 " rods.?
Chris :flag
[Modified by Clink69, 8:02 PM 1/7/2003]
Chris :flag
I have forged pistons and a solid cam and there is some noise when cold but not a rod knock sound. Unless they set it up with huge clearance, there should be some noise but not a loud noise. Does it go away when warm.
I would get the builders blessing on the noise and a signed copy of the warantee. Sounds like you're going to need it. I had noises on the first 406 that seemed too load to be normal coming from the valve train. Guess what? The cam went flat in 2000 miles. Live and learn. :U
Re: Stroker Oddities (Gordonm)
Well, maybe a rod knock is an overstatement. But it's defiinetly noisier than I expected. I've built and driven hot rods for years and the reason this one is different is because I paid SOMEONE ELSE TO BUILD IT for a handful of reasons. But none of my motors ever sounded like this one when cold. But I have never used forged pistons or built a stroker before, either.
He built it with 4 thou piston clearance. It is an Eagle Forged stroker kit with 6 inch rods. 4340 forged crank 3.750, H-Beam rods and SRP Dished pistons.
I have no problem at all "getting used to the noise." I wanna make that clear. My issue is ONLY if there is a prob with the motor!!! (there is no warranty on the engine other than defective materials).
Other than getting the darn car on the Dyno to get it tuned properly, it runs fine. And yes, all that noise (save for the roller rockers) does go away after it is warmed up. :jester
Sounds like just cold piston slap. The thing is forged pistons expand more than the block expands when warmed up. One machine shop I know of runs 180 degree coolant through the block as he bores and hones the cylinders so that it is accurate to operating temperature specs. You can guess that when cold, the bores would then be larger, but when warm the bore shrinks and the piston insides expands to match. It probably wouldn't be anything to worry about. Maybe get a block heater ;)
