Electric Fan options?
I am wanting to put on electric fan(s) on my 71 LT-1. 1 to clean up the front of the engine bay and to not bother with the %^%&*(& fan shroud during removal or installation of the radiator.
What options are there?
Retro fits?
New that are not too$$$?
Thanks, BT
Retro fits?
Thanks, BT
Re: Electric Fan options? (BLT-71)
I found a C4 fan from say an '87 or so works fine, mounted in a cut down depth and split on the sides near the upper A arm bolts....original shroud...
controlled by computer in my case...but could be done in a variety of other ways....sensor sw. in head...for instance...
GENE
GENE
I have Spal Duals, which is a twin 11" fan set up. Easy to install and top notch in quality.
Re: Electric Fan options? (groovyjay)
I am running dual fans from a 99 Trans Am. They fit nicely with a little trimming and work great. I have them wired to the computer so they run in slow and fast just like the factory designed
Re: Electric Fan options? (Bullyj)
I will be installing my dual spals when my Northern aluminum rad comes in...
aluminum fab bracket setup around the spals was done by gwhite75
[Modified by ylose, 9:13 AM 1/7/2003]
