ZZ4 oil gallery plugs?
Hey everybody,
Chris, 85_ToGo, is building up a motor around a ZZ4 block. We're trying to make sure the oil gallery plug under the rear main bearing cap is installed without removing the crank-shaft.
Freeze plugs came installed, some I'm hopeful. I haven't seen the block yet, I don't know if the three rear oil gallery plugs are installed.
Thanks!
Thanks!
