Underhood Quiz: Do I Need It?
Studied my underhood area today and noticed a lot of extra junk laying around. Would like to clean up/streamline...
Do I Need It?:
1. A/C drive belt? A/C in a vert is pretty much useless here in FLA. Belt doesn't seem to drive anything else but the compressor...
2. Heater hose (feed & return). Can a "jumper" hose be connected straight from pump to manifold? Heater is pretty much useless here in FLA.
3. "Deely-bobber" sticking out of thermostat housing? Looks like some sort of sending unit (it's not water temp). Has two right-angle vacuum hose-type(?) fittings that aren't connected to nuthin...would like to install a plain/smooth chrome (or painted) thermostat housing.
4. Vapor Recovery Tank/hoses? No smog laws here in FLA. Smells like gas. Do I remove & cap what's left?
5. Mushroom-looking thing, bolted to right-side (mid) intake manifold (as seated in car). Has one vacuum hose-looking fitting pointing forward, not connected. What is used to cover hole in manifold once this is (hopefully) removed?
Note: Car is currently running perfect.
Thanks in advance,
D. Ocean
Miami, FLA
[Modified by 74FLCONV, 7:24 PM 1/3/2003]
Do I Need It?:
Thanks in advance,
D. Ocean
Miami, FLA
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Underhood Quiz: Do I Need It? (74FLCONV)
1. No you don't need it if you aren't going to run A/C
2. You can buy rubber caps at parts stores that are held on by hose clamps, no need for a jumper hose then.
3. I think that's part of your apparently not working emissions system, called a the TCS system. Replace it with a regular manifold connection, but don't throw it away, you never know what's coming over the horizon from the pollution police.
4. I guess so, but if it's hooked up and working why bother.
5. I have no idea what part you are talking about, but if nothing is hooked to it, then apparently it isn't doing anything useful.
[Modified by Smokehouse69, 6:31 PM 1/3/2003]
#5 is the EGR valve. You could take it off but it's currently blocking a big hole in you intake manifold.... There is some argument to be made that your car will run better with it.
IMHO, Change to a non-egr intake and get performance and lose the hole in one move...
Re: Underhood Quiz: Do I Need It? (72rdstr)
#5 EGR. Several sources for EGR cover. One source - GM Performance Parts PN# 6269414, gasket is PN# 10140594.
#3 The "Deely-bobber" sticking out of thermostat housing, I believe, is the Thermal Vacuum Switch (TVS) for the EGR. If you remove the EGR, then there is no need for the TVS. Carb / TVS / EGR are connected by vacuum lines.
"The EGR system meters exhaust gas into the intake manifold for recirculation through the combustion cycle to reduce oxides of nitrogen emissions. (Corvette Shop Manual)". The EGR valve is controlled by a ported vacuum connection to the carburator. This keeps the EGR from working when the engine is at idle or under deceleration.
The Thermal Vacuum Switch, on the thermostat housing, keeps the EGR from working when the engine is below normal operating temperature (195 F).
I would hang on to any of this stuff you remove - never know when you may need it again.
