Oil pressure gauge line??
Old 01-03-2003, 11:43 AM
Sigforty
Sigforty's Avatar
Cruise-In IX Veteran
Default Oil pressure gauge line??
I want to replace the line from the block to the gauge while I am doing the radio in my car next month. I want to use the Autometer steel braided line, but I do not know what part number it is or how it will fit. Can anyone tell me which length (3,4,6 ft) and size (-3an, -4an).
Mark B.
Old 01-03-2003, 05:43 PM
redwingvette
Support Corvetteforum!
redwingvette's Avatar
Default Re: Oil pressure gauge line?? (Sigforty)
Sorry I can't answer your question. I used copper tubing when I replaced mine.
Old 01-03-2003, 05:48 PM
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
I'm interested also, since I'd like to replace my nylon line with a cool looking steel braided line. As far as length goes, I think 3 ft would probably be plenty long enough, but I guess you could go with the 4 ft just to make sure you had enough.
Old 01-04-2003, 10:04 PM
Sigforty
Sigforty's Avatar
Still no info. Someone has to know something. I thought I saw someone from the forum picked one up a while ago.
Mark B.
Old 01-04-2003, 10:53 PM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I haven't done an extensive search but so far I've found the smallest diameter SS braided tubing is 1/4 in. The fittings & stock tubing are for 1/8 inch tubing.
I bought an aftermarket universal-type copper set.
To Oil pressure gauge line??
Quick Reply: Oil pressure gauge line??
