Brake Console 1976 Question
On the rear metal support of the brake console there is a captive nut which faces toward the rear shelf. There is also hole on the shelf for a (spring loaded?) device about the size of a bolthead to go into. I assume you screw this mystery part into the metal bracket on the console and insert the (Spring loaded?) end into the hole on the shelf when installing the console. Is there a name and part number for this mystery part?
