need help again!
need help again!
Because of vibration troubles I"m going to remove the tranny and check the clutch & pressure plate. I"m stuck at the shifter / mounting plate. I"ve removed the bottom 2 bolts but the top one is between the shifter and mounting plate. How do you get this one out thanks again!
